Soloman
Jun 29, 2022Star
RBK763S (AX5400). SSID reset required
Ever since purchasing my new RBK 763S, I have had an issue with a requirement to setup a new SSID after my Internet connectivity is dropped, or if we experience a power outage. If I do not change th...
- Jun 30, 2022
Yes. I use 50% on mine. Seems to also help steer devices to RBS as well vs the RBR. Orbi systems are fairly powerful.
Jun 29, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
You don't need to change the SSID or should need a reset.
80 devices is kinda high...not sure if this will impact or cause what your seeing.
Can you disable say half of these device and see if this changes the behavior?
Soloman
Jun 29, 2022Star
Current Software version is V6.3.1.0_1.1.41. Separation is ~20 ft to 1 Satellite (also through walls) and ~35 feet to the second Satellite (also through walls). About half of the devices are wired using Ethernet and Netgear switches. When fewer items are connected I was still having issues connecting my iPad with the previous SSID, changing my SSID was a solution one of the Netgear Tech support reps suggested after walking through the initial setup with me.
- FURRYe38Jun 29, 2022Guru - Experienced User
Soloman wrote:
Current Software version is V6.3.1.0_1.1.41. Separation is ~20 ft to 1 Satellite (also through walls) < this would be WAY TOO close for this one RBS to the RBR.
and ~35 feet to the second Satellite (also through walls). About half of the devices are wired using Ethernet and Netgear switches.<What model # are these switches? When fewer items are connected I was still having issues connecting my iPad with the previous SSID, changing my SSID was a solution one of the Netgear Tech support reps suggested after walking through the initial setup with me.
What CAT# lan cable are you using?
- SolomanJun 29, 2022Star
Sounds good I will try separating the 1 Satellite that is within 20 feet - to greater than 30 feet. My LAN cables are mostly CAT6, although some of the in wall lines are still CAT5e. The switches are: GS208 (1), GS205 (2), GS908 (1), GS308V3 (1).
- SolomanJun 30, 2022Star
Should I be looking at a different model of Orbi for my home? You implied that the 80+ devices were a bit too much for the RBK763S. Would the RBK850 series, or even the RBK950 series handle this quantity better - the total number of devices supported is a bit vague in the specs. One of the reasons I avoided the higher end models (in addition to the price difference ) is that with a 3100 sq foot house - these packages might overwhelm the size of the home and cause other issues.
