Soloman
Jun 29, 2022Star
RBK763S (AX5400). SSID reset required
Ever since purchasing my new RBK 763S, I have had an issue with a requirement to setup a new SSID after my Internet connectivity is dropped, or if we experience a power outage. If I do not change th...
- Jun 30, 2022
Yes. I use 50% on mine. Seems to also help steer devices to RBS as well vs the RBR. Orbi systems are fairly powerful.
Soloman
Jun 29, 2022Star
Sounds good I will try separating the 1 Satellite that is within 20 feet - to greater than 30 feet. My LAN cables are mostly CAT6, although some of the in wall lines are still CAT5e. The switches are: GS208 (1), GS205 (2), GS908 (1), GS308V3 (1).
Soloman
Jun 30, 2022Star
Should I be looking at a different model of Orbi for my home? You implied that the 80+ devices were a bit too much for the RBK763S. Would the RBK850 series, or even the RBK950 series handle this quantity better - the total number of devices supported is a bit vague in the specs. One of the reasons I avoided the higher end models (in addition to the price difference ) is that with a 3100 sq foot house - these packages might overwhelm the size of the home and cause other issues.
- FURRYe38Jun 30, 2022Guru - Experienced User
- SolomanJun 30, 2022Star
Thanks for that reference, if that is blanket statement for the whole Orbi line, then at least I know that my issues are not related to the number of low end IOT devices that I have connected through the system. Most of the time these devices require little bandwidth -i.e. switches and sensors etc. So if I see the issue again, I will not have to look at replacing the unit.
I think for the most part spacial distances between the RBR and RBS will resolve what your seeing.
