Soloman
Jun 29, 2022Star
RBK763S (AX5400). SSID reset required
Ever since purchasing my new RBK 763S, I have had an issue with a requirement to setup a new SSID after my Internet connectivity is dropped, or if we experience a power outage. If I do not change th...
- Jun 30, 2022
Yes. I use 50% on mine. Seems to also help steer devices to RBS as well vs the RBR. Orbi systems are fairly powerful.
Jun 30, 2022Guru - Experienced User
Soloman
Jun 30, 2022Star
Thanks for that reference, if that is blanket statement for the whole Orbi line, then at least I know that my issues are not related to the number of low end IOT devices that I have connected through the system. Most of the time these devices require little bandwidth -i.e. switches and sensors etc. So if I see the issue again, I will not have to look at replacing the unit.
- FURRYe38Jun 30, 2022Guru - Experienced User
I think for the most part spacial distances between the RBR and RBS will resolve what your seeing.
- SolomanJun 30, 2022Star
One more question - would reducing the transmitter power also help alleviate this issue?
I could take them down to 50% based on the size of our house.
