JAF47
Sep 04, 2023Aspirant
RBK840 won't connect to the internet
I purchased an RBK840 to improve WiFi coverage. I used the phone app for setup. Everything went well until I connected it to my modem, a Netgear CM700. The app indicated that the cable was connected,...
- Sep 08, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Sep 04, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
JAF47
Sep 07, 2023Aspirant
I can now connect to the internet, but when I attempt to load a web page, I get a "Connection isn't private warning (Windows WiFi) or "Can't establish secure connection" error (Mac connected to router by ethernet cable).
- FURRYe38Sep 08, 2023Guru - Experienced User
https://www.howtogeek.com/874436/how-to-fix-your-connection-is-not-private-errors/
https://kinsta.com/blog/safari-cant-establish-a-secure-connection-to-the-server/
- JAF47Sep 08, 2023Aspirant
Update:
I logged on to orbilogin.com on my desktop PC to look into updating the firmware as suggested in the user's manual. When I did, I was returned to the set-up process. I did get a notice of an IP address conflict, and that it had been changed to 10.0.0.1. Then a screen appeared to allow updating the firmware, which I did. After that the system is working great with a noticeable increase in speed over the old router.
Enjoy. 📡
