BWest1
May 07, 2024Star
rbk843s - different link rates on 2.4ghz
RBK843S (RBR840, RBS840) all running v4.6.14.5. I noticed that the router shows 2.4ghz wireless mode "up to 1147 Mbps" but both satellites show 2.4ghz wireless mode "up to 574 Mbps" (both router and...
May 07, 2024Guru - Experienced User
So the 840 series is a AX5700 system or is supposed to be:
https://www.netgear.com/images/datasheet/orbi/rbk842.pdf
Not a AX6000, the 850 series is the AX6000 series which is a combined Wi-Fi speed only.
Technical Specifications show the following for the 840 series:
• AX5700 Router and AX5700 Satellite
(900 + 2400 + 2400Mbps)
900 being 2.4Ghz,
2400 for both 5Ghz user front haul and system backhaul speeds.
Possible bug in FW. Possible NG changed something as well.
Not sure if the 840 series will get same v7 FW update as the 850 series.
Got a picture of the box and specs need on it?
- BWest1May 07, 2024Star
As I stated, apparently the hardware was upgraded at some point, here is the actual link on NG for my system:
https://www.netgear.com/home/wifi/mesh/rbk843s/
Also, the link on the support page for the firmware downloads for the 843s (https://kb.netgear.com/000065692/RBR840-RBS840-Firmware-Version-4-6-14-5) shows support for AX6000 link rate in the release notes.
As you can see, it actually IS an AX6000 with the hardware specs I identified in my original post (and these are exactly the same as the hardware specs on the 850). These are quite different from the specs you posted, which apparently represent the original version.
In any case, I'm not getting the documented link rates from the satellites (either the original AX5700 version or the AX6000 version I have).
- FURRYe38May 07, 2024Guru - Experienced User
Ah ok. Makes sense now. So ya, I guess they changes the link rates then seen on the RBR and RBS 840 series.
I believe the link rates seen on the RBS web pages reflect actual connection based on signal and noise quality between the units.
Also of interest in the actual firmware chk file for v4.6.14.5 for the 840 test for "machid" = "801000e" or "801010e" and the firmware chk file for v7.2.6.31 also shows a test for "machid" includes both of these in a much longer list, so that's why I am assuming the hardware is supported by the v7 firmware.
I am not looking at the actual link rates used by a device, I am logging in to the satellite (in my system it's 10.0.0.20) and see on the status page that the 2ghz link rate is set to max 573Mpbs. that's a hardware / firmware limit. Very different from logging in to the router, there are no options to configure anything for the satellite other than a manual update of the firmware.
- CrimpOnMay 07, 2024Guru - Experienced User
My impression is that most customers utilize that 90 days of 'complimentary support' during the initial setup, or let them expire before having a reason to call. I so envy people who can "contact support". (My 90 days ran out in 2016.)
(Somehow I suspect that Netgear support would respond "huh?" and struggle to grasp the question.)
It is not clear to me what information the Netgear firmware uses to display those Link Rate values on
- The router Advanced Tab, Show statistics, and
- The satellite home web page
Maybe the values are hard coded into the web code? No one knows.
My guess is the only to confirm is to find a WiFi device that supports 2.4G 802.11ax, 1024QAM (and can be made to use only the 2.4G band), stand very close to a satellite, and see what Link Rate the device (and the Orbi 'app') report.
I had asked about this for the 850 series, was told that the rates seen between the RBR and RBS are dynamic based on signal quality between the units.
