BWest1
May 07, 2024Star
rbk843s - different link rates on 2.4ghz
RBK843S (RBR840, RBS840) all running v4.6.14.5. I noticed that the router shows 2.4ghz wireless mode "up to 1147 Mbps" but both satellites show 2.4ghz wireless mode "up to 574 Mbps" (both router and...
BWest1
May 07, 2024Star
As I stated, apparently the hardware was upgraded at some point, here is the actual link on NG for my system:
https://www.netgear.com/home/wifi/mesh/rbk843s/
Also, the link on the support page for the firmware downloads for the 843s (https://kb.netgear.com/000065692/RBR840-RBS840-Firmware-Version-4-6-14-5) shows support for AX6000 link rate in the release notes.
As you can see, it actually IS an AX6000 with the hardware specs I identified in my original post (and these are exactly the same as the hardware specs on the 850). These are quite different from the specs you posted, which apparently represent the original version.
In any case, I'm not getting the documented link rates from the satellites (either the original AX5700 version or the AX6000 version I have).
May 07, 2024Guru - Experienced User
Ah ok. Makes sense now. So ya, I guess they changes the link rates then seen on the RBR and RBS 840 series.
I believe the link rates seen on the RBS web pages reflect actual connection based on signal and noise quality between the units.
