TheGrumpyGent
Dec 14, 2021Tutor
RBK850 - How to Clear the Netgear Smart Parental Controls Pop-up?
Hello all, running the AX6000 Orbi. I recently had Smart Parental Controls turned off and refunded, as it disables Access Control (you get one or the other). Support was great and helped get that taken care of, but unfortunately I had to factory reset the Orbi to get Access Control back.
Everything is working now beyond Access Control being "All or Nothing" (i.e. it blocks the guest network too) but that's an enhancement request. Now on to my question:
In the Orbi app, if I click Device Manager I get a pop-up for Smart Parental Controls, "Premium Plan Please Activate". If I click the X to close it, it takes me back to the Orbi app home screen. There is also a button to "Set Up Now", but naturally I'm a bit hesitant to do it as I don't want to lose Access Control nor do I want to do another factory reset.
Does anyone know if there's a way to get rid of that without setting up Smart Parental Controls, or will I need to bug support again? Thanks in advance!
