InstantDreams
Oct 12, 2022Aspirant
RBK850 Dropping Internet Connection During Work Hours
Model: RBR850,RBS850,Alcatel-Lucent Fibre ONT Firmware: v4.6.9.11 OS: Windows 10, Linux Environment: Telus PureFibre direct to RBR850, wired backhaul to RBS850, wired LAN to servers and desktop c...
Oct 12, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
"My RBR850 has a number of servers, cameras, and IoT devices in the range 192.168.1.10 - 192.168.1.100. Any other devices connecting use DHCP for 192.168.1.101 onwards." Are the dynamically addressed on the RBR or do you set a IP address reservation on the RBR for these devices?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Have you had the following enabled? Armor, Smart Parental Controls, or Traffic Meter.
Do you have any RBS deployed?
Is SIP ALG disabled on the RBR?
- InstantDreamsOct 12, 2022Aspirant
No. There has never been any direction from NetGear - or any other manufacturer - to perform a factory reset after a firmware upgrade.
I have a good quality CAT6 cable between my fibre ONT and the RBR850.
Statc IPs are defined directly on most devices. Six IP cameras have MAC address IP reservation.
Wireless connections are unaffected. Internet connectivity is affected.
2.4GHz is on Auto, 5GHz is on 48.
Armor is not enabled.
Smart Parental Controls are not enabled.
Traffic Meter is not enabled.
There is one RBS850 connected via wired backhaul.
Current settings:
Advanced | Setup | WAN Setup | NAT Filtering | Secured
Advanced | Setup | WAN Setup | NAT Filtering | Disable SIP ALG is unchecked
Thank you for your time in replying.
- FURRYe38Oct 12, 2022Guru - Experienced User
As a troubleshooting step, IF problems are seen after a FW update, if after most troubleshooting steps have been tried or exhausted, common last resort step is to factory reset. Been many issues solved by this.
If you using static IP addresses ON devices, common normal and standard networking practice for using Static IP addresses is to use these out side of the default IP address pool range. Not with in it.
Is the RBS directly connected to the back of the RBR or is there a LAN switch or LAN patch panel in between?
Current settings:
Try SIP ALG enabled.
FURRYe38 wrote:
InstantDreams wrote:Has a factory reset and setup from scratch been performed since last FW update?
I acknowledge this statement. If the settings changes detailed below do not resolve this issue I will perform a factory reset and reconfiguration.
I understand your question now. I have devices in the range 192.168.1.10 to 100 that either set their own static address or use MAC address reservation. All devices outside of that range use DHCP and are assigned an IP in the range 192.168.1.101 to 254. The devices "seen" by the RBR are in the static range.
There are 5 wifi SSIDs shows under the Network Status, the closest of which is at 82% strength on Channel 4.
2,000SqFt
It is a direct connection
Current settings:
I have performed the following updates to the router settings based on your suggestions and other solutions found on this forum:
Turned off UPnP
Advanced | Advanced | UPnP | Turn UPnP On | UncheckedAdjust Time Settings
Advanced | Administration | NTP Settings | Set your preferred NTP Server | ca.pool.ntp.org
Advanced | Administration | NTP Settings | Time Zone | (GMT-07:00) Mountain Time (US & Canada)Turn off SIP ALG
Advanced | Setup | WAN Setup | Disable SIP ALG | CheckedI will monitor the performance over the next day or two and report back. Thank you again.
