magoldsm1
Jan 07, 2021Aspirant
RBK850 Guest Network Port Forwarding
My goal is to provide my students access to a machine in my home without allowing them onto my general home network. What I was thinking was this:
- Isolate the machine for student use on the guest network.
- Enable port forwarding for desired ports to that machine.
This doesn't seem to be possible (at least with my current firmware. Due to the NAT loopback issue, I am still running V3.2.16.1_1.4.4). While the port forwarding web page allows me to specify the 192.168.2.x network, when I Apply, it is rejected.
Does anyone have any suggestions? I looked at VLAN in the manual, but the entire discussion revolves around bypassing NAT, which is not what I'm trying to do.
Thanks,
Michael
Guest Network already gets a assigned the .2.### address. Guest Network is already on the WAN side of the router thus there is no need for port forward Guest Network which isn't supported.
- magoldsm1Aspirant
I mis-stated my question. I'd like to give the students *remote* access to the machine in my home, while maintaining isolation of that machine from the rest of my home network.
Thanks,
Michael
