MikeG1970
Apr 20, 2025Aspirant
RBK850 Not Connecting/Struggling to Connect to Microsoft Exchange Servers
Need some help figuring this one out - in the last week or so, my Outlook is often failing to connect (or trying to connect for upwards of 45 seconds) due to some blocking/connectivity issues. My PC ...
MikeG1970
Thanks, but I already am using CloudFlare
Here is my IPv6 settings.
MikeG1970
Here is my IPv4 setting.
- CrimpOnApr 20, 2025Guru - Experienced User
Using a VPN is likely to result in using different DNS lookup. Maybe change to Google (8.8.8.8)?
If we knew the actual URLs that Office and One Drive use, the nslookup command might provide information.
Does Windows (without the VPN) eventually connect and the problem is the extreme delay?
- MikeG1970Apr 20, 2025Aspirant
thanks for additional thinking here but I confirmed that the Cloudflare Warp does us their DNS (1.1.1.1).
Oddly, this problem only started like 2 weeks ago.
Yes, it ultimately it does connect, but it takes excessively long (could be as long as 30 to 45 seconds why it is "connecting to server").
Again this happens in both Outlook when trying to first connect to Exchange and with OneDrive as I as try to save a file.
At first I thought this was a MS Firewall issue, but the fact that it doesn't happen when I directly wired to the ONT (and only happens when I am directly wired to the Orbi) kind of confirms it is something with the Orbi.
Doing even more digging...it possibly appears to be related to an "old" bug that Netgear was alerted to previously!
Seems to be related to IPv6 and "IPv6 Filtering" - Default setting is "secured" which research shows may cause issues (hence it was ticketed to support) ...I just switched it to "Open" and it appears to have resolved the issue.
Some testing here - https://test-ipv6.com/
- With Cloudflare Warp (IPv6 Filtering set to Secure) - 10/10 (and quickly)
- With Cloudflare Warp off (and IPv6 Filtering set to Secure) - fails tests (and I get the delays with connecting with the Exchange servers)
- IPv6 Filtering set to Open (and Cloudflare Warp off) - test gets 10/10 quickly and I don't see any delays on connecting with the Exchange servers.
I will clearly have to explore this more but this is promising so far!
