MikeG1970
Apr 20, 2025Aspirant
RBK850 Not Connecting/Struggling to Connect to Microsoft Exchange Servers
Need some help figuring this one out - in the last week or so, my Outlook is often failing to connect (or trying to connect for upwards of 45 seconds) due to some blocking/connectivity issues. My PC ...
KMDonlon
Apr 20, 2025Virtuoso
Doesn't setting IPv6 to AUTO Detect revert to another setting? Mine goes to DHCP...
My IPv6 would work for about 5 hours or so then fail to connect. I tried multiple times a month and a half ago to trouble shoot with no luck, definitely a flaw in the firmware. I was using DHCP... still waiting on Netgear to get this resolved.
MikeG1970
Apr 28, 2025Aspirant
Completely agree. After a few days of testing, there is clearly a defect in/related to the Orbi.
I have been forced to disable IPv6 to ensure consistent access (and using CloudFlare WARP which gives me IPv6 via its VPN).
Very disappointing given that problems here only started a few weeks ago so it isn't clear to me if its is the firmware specifically or the actual hardware is failing (not yet ready to do a complete reset of the Orbi software).
- FURRYe38Apr 28, 2025Guru - Experienced User
Seems for those that had native IPv6 on prior FW versions that this newer FW version is broke and not a HW issue. You'll need to disable IPv6 to continue with this version of FW or downgrade back to prior working versions of FW where IPv6 is working. Please make contact with NG support about this as well.
