thierry38
Jun 05, 2021Star
RBK850 Routeur LAN configuration
Hi I configured an RBK850 (without satellites for the present time) connected to ans ISP router (network 192.168.1.<x> with HDCP server). So, at the end of installation, my orbi network is 10.0.0...
Jun 05, 2021Guru - Experienced User
Did you power OFF the ISP router for 30 seconds then back on as well after you applied the change?
Can you bridge the host router by chance? This is a double NAT condtion...
- thierry38Jun 05, 2021StarYes, I powered off the ISP router and I can access to internet. I just received an answer for neatgear support
It seems the router DOES NOT support to have a 192.168.2.2 IP @. If I choose 192.168.2.1, it seems it’s working well.
I will continue tomorrow (11 PM in France now) And I will give you more information later. I lost several hours with the pb
Thanks- FURRYe38Jun 05, 2021Guru - Experienced User
I now mine works on 192.168.0.1. I've never tried 2.1 though...Hmmm.
Have a good night.
- thierry38Jun 06, 2021StarHi,
Just for information, with a router IP @ of 192.168.2.1 instead of 192.168.2.2, everything are working well.
After this modification, I successfully
- desactivate the router DHCP fonction (used instead a DHCP located on my network)
- add two additional satellites
So, it seems there is a bug in the orbi firmware which doesn’t support 192.168.2.2 as router address
Best regards
