thierry38
Jun 05, 2021Star
RBK850 Routeur LAN configuration
Hi I configured an RBK850 (without satellites for the present time) connected to ans ISP router (network 192.168.1.<x> with HDCP server). So, at the end of installation, my orbi network is 10.0.0...
thierry38
Jun 05, 2021Star
Yes, I powered off the ISP router and I can access to internet. I just received an answer for neatgear support
It seems the router DOES NOT support to have a 192.168.2.2 IP @. If I choose 192.168.2.1, it seems it’s working well.
I will continue tomorrow (11 PM in France now) And I will give you more information later. I lost several hours with the pb
Thanks
Thanks
Jun 05, 2021Guru - Experienced User
I now mine works on 192.168.0.1. I've never tried 2.1 though...Hmmm.
Have a good night.
- thierry38Jun 06, 2021StarHi,
Just for information, with a router IP @ of 192.168.2.1 instead of 192.168.2.2, everything are working well.
After this modification, I successfully
- desactivate the router DHCP fonction (used instead a DHCP located on my network)
- add two additional satellites
So, it seems there is a bug in the orbi firmware which doesn’t support 192.168.2.2 as router address
Best regards- FURRYe38Jun 06, 2021Guru - Experienced User
AH ya, Ok. I presume the RBRs IP address should always be .0 or .1. Maybe something NG put in. Most routers IP address usually end in .1 anyways.
Glad it's working now. Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemPlease mark your thread as solved so others will know.
Enjoy.
