ekhalil
Aug 13, 2021Master
RBK850 Series - Firmware Update v4.6.3.9 - Issue with wired satellites
 I see that there is a new firmare for RBK850 to enable parental control. The firmware is v4.6.3.9.  I downloaded this firmware and installed it.     https://www.netgear.com/support/product/rbr850.asp...
- Aug 17, 2021
Factory reset of the Router solved the problem with wired satellites. :)
Aug 13, 2021Guru - Experienced User
