DKS007
Mar 09, 2023Follower
RBK850
Hi, how to connect the satellites after changing to AP mode?
michaelkenward
Mar 10, 2023Guru - Experienced User
Find the IP address of whatever the RK850 is. (That's not a Netgear model number.)
RBK something or other (852?) is a bundle with a router (RBR850?) and satellites (RBS850?).
You should be able to get the IP address from your main router, or from the WiFi connection.
Then aim a browser at that IP address and take things from there.
Or use WPS.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
