EsuNYC's avatar
EsuNYC
Follower
Jul 26, 2020
RBK852 — Orbi WiFi 6 System AX6000 Compatible modem
I need a modem that is compatible with the RBK852 - AX6000 wifi system.
1 Reply
  • plemans's avatar
    I'd be more concerned about a modem that is compatible with your isp. That's the key.
    If you're getting a strict modem only device, it should work with the router but you need to make sure its compatible/certified to work with your isp.
