EsuNYC
Jul 26, 2020Follower
RBK852 —Orbi WiFi 6 System AX6000 compatible modem
I don't know what cable modem to buy to use with the RBK852 - AX6000 wifi system.
Jul 27, 2020Guru - Experienced User
NG CM1000, 1100 or 1200 work well. Most any cable modem works with Orbi systems. First ask your ISP about what they support in regards to user owned modems.
