Garwoofoo
May 25, 2022Apprentice
RBK852 - iPhone occasionally losing connection
I've observed some strange behaviour with my Orbi system (RBR850, one wired satellite, one wireless satellite) and my iPhone 13 mini. Periodically (maybe once a week or so) the phone will lose it...
- May 22, 2023
Hi There,
What is your iOS?
Apple in iOS 16 introduce a lot of Wi-Fi problems according to forums. One of the main ones discuss was that iPhone is connected to the network but it is choosing to use Cellular data over Wi-Fi if it thinks data is better than Wi-Fi. Apple improved this but there will be occasions where is still choses cellular data over Wi-Fi.
Now currently there appears to be a bug where it appears that the iPhone is taking forever to connect to the network but when you leave the settings tab and come back it is connected but top corner shows it is still using cellular data.
Please check this out: (1) iOS 16.4.1 (a) WiFi issues : ios (reddit.com)
Garwoofoo
Thanks. I had all three of those active so I have disabled them all and will see if the problem recurs. It's an occasional problem so it may be a while before I can really tell if it's fixed.
I think you might be onto something though - looking at the device in the Orbi dashboard, it has immediately reverted to its proper name.
May 25, 2022Guru - Experienced User
Ya, Apples WiFi Private Address is the main cause for that one.
- GarwoofooJun 01, 2022Apprentice
Just an update on this: disabling Wifi Private Address on its own didn't resolve the problem. The same issue reoccurred after a few days.
Now trying disabling all three to see if that fixes things. If it does then I can try to reactivate them one by one to see which one (if any) is causing the issue.
- FURRYe38Jun 01, 2022Guru - Experienced User
Maybe the iCloud relay. Odd that mines not doing this. I've only disabled private address.
