Garwoofoo
May 25, 2022Apprentice
RBK852 - iPhone occasionally losing connection
I've observed some strange behaviour with my Orbi system (RBR850, one wired satellite, one wireless satellite) and my iPhone 13 mini. Periodically (maybe once a week or so) the phone will lose it...
- May 22, 2023
Hi There,
What is your iOS?
Apple in iOS 16 introduce a lot of Wi-Fi problems according to forums. One of the main ones discuss was that iPhone is connected to the network but it is choosing to use Cellular data over Wi-Fi if it thinks data is better than Wi-Fi. Apple improved this but there will be occasions where is still choses cellular data over Wi-Fi.
Now currently there appears to be a bug where it appears that the iPhone is taking forever to connect to the network but when you leave the settings tab and come back it is connected but top corner shows it is still using cellular data.
Please check this out: (1) iOS 16.4.1 (a) WiFi issues : ios (reddit.com)
Straq
May 22, 2023NETGEAR Expert
Hi There,
What is your iOS?
May 22, 2023Guru - Experienced User
Though I've not had the 8 series online in a bit, my iphone 12 Pro Max is on 16.4.1 as of last month and has been working well with 9 series Orbi and other routers i've been testing. I haven't see this delay in connecting. I did have problems on prior iOS version I had loaded. I'd have to pull up an bug report to remember what I had in regards to speeds I was seeing on that version of iOS was bad. After I updated to 16.4.1, speeds are back to spec and phone connections are fine.
Another item those reddit user should check is the WiFI Private IP address feature on Apple devices. This has been causing problems since Apple pushed this feature. Its enabled by default and though for securiy reason is good to have, realistically, is not needed while at home on the home network. Travelling of course it should be enabled. I don't have this enabled on any of my devices while at home so I don't encounter odd issues. Something both Apple and Android users should be ware of. I believe our user here in this thread is aware.
