TheGrumpyGent's avatar
Nov 30, 2021
RBK852 - Lock Down Wifi Network?
Hello, new Orbi owner here!  So far very happy with the speeds, but I do have a question:  The last time I had an Orbi years ago, MAC filtering existed in the web interface. When I go to Advanced -> Security -> Access Control, I get the message "To use Access Control, please use the Orbi App."  However, I don't see any option for MAC filtering in the app.
What I'm trying to do is lock down the main wifi network to just the devices I have, so the kids can only share the guest network to their friends etc when they visit.  Doesn't have to be MAC filtering, just whatever the equivalent would be in the current firmware (V4.6.3.16_2.0.51 in my case).
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Mac filtering is not supporting on Orbi app. By device and IP only I believe.
    Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
    Thank you
    • TheGrumpyGent's avatar
      TheGrumpyGent
      Tutor
      Thanks, I had a feeling that was the case.  Is there any way to prevent any further devices from being added to the wifi network (i.e. if the device doesn't already exist, it won't allow others to connect)?
      • FURRYe38's avatar
        I dont' believe so. Having apps like Armor would help notify you if a new device being connected or got connected I believe.
        Something to check on over in the Armor foum if want too:
        https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
        https://www.netgear.com/landings/armor
        The few times I used Armor I saw notifications of new devices had connected. I don't use it much since my household is all adults.
        If your finding un-authorized devices connecting to the system, you might start finding out where and why these are being connected. Is the SSID password being given out when it shouldn't be? Might change the PW and both SSID and PW and see if something changes...user complaints?
  • CrimpOn's avatar
    CrimpOn
    Would you mind confirming whether Parental Controls are enabled on this new Orbi system?
    (My old RBR50 has never used Parental Controls and I can attest that Access Control remains available as always.  I'd like to know if this "Please use the app..." situation is a result of (a) enabling Parental Controls, or (b) the new AX model being 'different'.)
    I am also uncertain whether enabling Access Control with "Block new devices" applies to the guest WiFi network.  I can test that some time, but since you have no Access Control at all, the results would  not be useful.
    Is there a reason the kids cannot be trusted to share only the guest WiFi credentials with their friends?  You could change the primary WiFi password and force the kids to use only the guest WiFi for their own devices.  If they don't know the password, then they can't share it.
      I do have Parental Controls active on the Orbi.  I don't see any option to "Block new devices" (which would definitely solve what I'm looking for).
      I may not have been clear - I trust the kids to share the guest wifi as much as they want, they have accidentally given out the main wifi network in the past (its easy to share a wifi network from an iphone).  I just want to lock down new devices on my main wifi network.
      • CrimpOn's avatar
        CrimpOn
        So, it remains unknown whether Parental Controls has disabled Access Control or whether the new Orbi model doesn't have Access Control to begin with.
        Maybe the kids would be open to "It is so easy to accidentally share our home WiFi password on iPhones, if you 'forget' the WiFi and connect to the Guest WiFi instead, then that can't happen any more. Your iPhone will still work great, and Grumpy Dad will not be anxious any more."
