HarrySg
Aug 12, 2020Follower
RBK852 - Setup issue with Singtel
Hi, Just bought RBK852 with an addition RBS850. Spent hours to setup to my Singtel ONT modem but to no avail. The Obri app can’t find the Obri RBR850. In the Wi-Fi interface at my phone, it shown t...
Aug 13, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here by chance? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Swap LAN cables between the modem/ONT and RBR. CAT6 is recommended.
Use a wired PC and web broswer to setup the RBR and system.
