KBDMB1
Mar 21, 2022Aspirant
RBK852 - Slow download speeds with NZB's - QoS issue?
Hi There, I have been loving our Orbi RBK852 setup at home, great coverage and ease of use but I have been noticing some slow download speeds when using NZB files to download various types of fil...
- Apr 02, 2022
Just wanted to add the resolution to this topic, it seems that the slow download speeds were on my end. I recently switched to windows 11 and it did not cross my mind, so after doing some research and some tests, I reinstalled the lan drivers on my desktop and all of an sudden, the speeds were capped.
Thanks for the help and hints.
CrimpOn
Mar 22, 2022Guru - Experienced User
KBDMB1 wrote:
I couldn't find anyway to prioritize a certain device, is that somehow possible?
Not on the Orbi products. No. Being able to actively manage QoS is often a feature of "gaming routers".
KBDMB1
Apr 02, 2022Aspirant
- FURRYe38Apr 02, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
