rayraysf
Oct 12, 2020Guide
RBK852 / AX6000 and Samsung Frame TV wifi issues
I have a brand new Samsung Frame TV and it can't consistently connect to my wifi set up. I tried following the steps outlined in this post: https://community.netgear.com/t5/Orbi/TV-s-wont-connect-t...
- Oct 22, 2020
After speaking with both Samsung and my ISP and after trying a whole hosts of solves, I came to same conclusion that you did. I also think the wifi receptor on the Samsung frame is poor. In my last experiment, I moved one of my router satellites right next to the Samsung Frame TV box and that worked much better. I then also tried wiring the TV box into my router satellite via ethernet cable and it worked even better (not surprisingly). Moving forward, I'm going to put my router satellite right next to the TV box and wire the TV in via ethernet. Not ideal as I think the frame should have a much better wifi receptor, but this is the solution that I'm going with.
Oct 12, 2020Guru - Experienced User
Be sure the TVs firmware is up to date from the mfr.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try disabling AX mode on either frequency.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Try Setting CTS to 2347. Save settings and reboot the router and satellite(s).
Contact the TVs mfr for additional help and information regarding there product.
- rayraysfOct 12, 2020Guide
Thanks for your response
My modem is a Motorola DOCSIS 3.1 Cable Modem
TV firmware is up to date
RBR and RBS are more than 30 ft apart. House is ~2200 square feet
Have tried disabling AX mode and different channels for 2.4 and 5.0 but that didn't help
Have also tried disabling features as you suggested but still not connected
Pretty sure this is a Netgear Orbi problem and not Samsung as I have 25+ devices also connected to wifi and no issues there. Only issue is with the Samsung TV
- FURRYe38Oct 12, 2020Guru - Experienced User
I would make contact with NG support AND Samsung. If the TV is the only problem device while your others are not having any issues, I would start with Samsung first...
- Mikey94025Oct 12, 2020Hero
rayraysf wrote:Have tried disabling AX mode and different channels for 2.4 and 5.0 but that didn't help
Just checking - Did you also set CTS/RTS Threshold to 2347 in orbilogin.com's Advanced Wireless Settings?
It's odd that you would have Samsung TV problems without many other Samsung TV problems also complaining here. What wireless security option are you using (e.g., WPA2-PSK/AES)? Does the Samsung TV see your SSID but is unable to connect? Or does it not see the SSID at all?
- Chuck_MOct 13, 2020Mentor
You could be experiencing some form of intermitted Electromagnetic Interference (EMI).
Do you have any LED equipped products near that Samsung TV? Some LED products are not properly shielded and have been known to cause 802.11 interruptions.
