rayraysf
Oct 12, 2020Guide
RBK852 / AX6000 and Samsung Frame TV wifi issues
I have a brand new Samsung Frame TV and it can't consistently connect to my wifi set up. I tried following the steps outlined in this post: https://community.netgear.com/t5/Orbi/TV-s-wont-connect-t...
- Oct 22, 2020
After speaking with both Samsung and my ISP and after trying a whole hosts of solves, I came to same conclusion that you did. I also think the wifi receptor on the Samsung frame is poor. In my last experiment, I moved one of my router satellites right next to the Samsung Frame TV box and that worked much better. I then also tried wiring the TV box into my router satellite via ethernet cable and it worked even better (not surprisingly). Moving forward, I'm going to put my router satellite right next to the TV box and wire the TV in via ethernet. Not ideal as I think the frame should have a much better wifi receptor, but this is the solution that I'm going with.
alohia
Oct 22, 2020Aspirant
I have also experienced the same with Samsung Frame TV. The TV seems to have a horrible wifi receptor. All my other devices are able to successfully connect to all my wifi networks at the exact same spot whereas this TV is just unable to catch a good strength for the signal.
I believe the problem is with the wifi receptor on the Samsung Frame TV. If you are able to get any information from Samsung, then please let me know as well.
rayraysf
Oct 22, 2020Guide
- FURRYe38Oct 22, 2020Guru - Experienced User
Thanks for letting us know. Glad it's working better.
Enjoy. :smileywink:
