stackmann
Dec 13, 2021Follower
RBK852 2.4 GHZ dropout
I HAVE A SMART HOME WITH 48 DEVICES AT 2.4 GHZ. I PURCHASED A RBK852 (WITH ONE SATELLITE) AND AM STILL HAVING ISSUES WITH DROP OUTS. IF I ADD ANOTHER SATELLITE, WILL IT CORRECT THE ISSUE?
Dec 18, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
