sjtNJ
Nov 12, 2019Guide
RBK852 As bride or Satellite?
Hey guys, Me again -- hopeful someone can help. I'm struggling on the range. Since they are not selling AX Satellites any time soon and I cannot hardwire all, do you know if I can buy another rou...
Nov 13, 2019Guru - Experienced User
You can get another 8 series kit and use the RBS as the 2nd sat. The RBR can only be used in router or AP mode though. Doesn't work as a satellite.
