sfung83
Dec 28, 2021Aspirant
RBK852 behind DDWRT VPN
Hi network gurus. Bit of a confused networking novice here. I've got an R7000 running DDWRT mainly for the policy based routing for specific IPs through a VPN client. I'd like to relieve it of DH...
CrimpOn
Dec 31, 2021Guru - Experienced User
sfung83 wrote:
What would be the benefit (appart from add blocking) of using pihole as the dhcp server?
Well, this would be a "growth opportunity" as you learn how to manage DHCP IP reservations on a different system.
There are users who seriously maintain that the Orbi DHCP process is flawed*. Maybe the Pi-hole DHCP process is flawed in different ways? If you have invested much time and effort into the R7000 DHCP setup, I don't see much gain from switching.
* The biggest complaint (which I agree with) is that creating an IP reservation for a device will not cause the device to switch from an existing IP address to the one the user wants it to have. Every time the device goes to renew the lease, the Orbi says, "oh, you are using that IP? Cool. Keep using it." When what it should say is, "oh, no you don't. says here in my tables that you need to use this other IP. Change now!"
(I paraphrase a bit.)
sfung83
Jan 05, 2022Aspirant
Not a bad argument at all. I'm a bit of an amateur tinkerer and serial hobbyist so I'll add it to the list of things to work out how to do! Also love how you've somehow managed to humanise an Orbi haha
