Erte
Dec 07, 2019Follower
RBK852: buying two and using both satellites in one system
I am looking at buying Two RBK 852, each with a router and satellite. Could I then use both satellites with the router and use the remaining router elsewhere? This is a little pricey, but wonderin...
Dec 08, 2019Guru - Experienced User
