johnny5126
Feb 29, 2020Aspirant
RBK852 Cannot do a speedtest
Under Qos setup in AP mode, when I try to test the speed, I get the error: The Speedtest failed to detect the bandwidth, please check your Internet connection or try again later. I get intern...
- Feb 29, 2020
Try setting the IP and DNS to Dymanic instead of Static...
Feb 29, 2020Guru - Experienced User
Is the RBR set for static or dynamic IP and DNS addressing? I saw this issue late last year while in AP mode while using Static IP and DNS addresses. Works when using Dynamic addressing. NG fixed this in a later version of FW.
johnny5126
I just updated to the latest firmware when I got these 2 days ago. It's set to AP mode, static ip, dns 1.1.1.1.
- FURRYe38Feb 29, 2020Guru - Experienced User
- johnny5126Mar 01, 2020Aspirant
And that fixed it and the NTP server as well. Another bug that needs to be squashed....
- FURRYe38Mar 01, 2020Guru - Experienced User
IT has been. You can wait for next FW update or ask for the beta.
Enjoy. :smileywink:
