johnny5126
Feb 29, 2020Aspirant
RBK852 Cannot do a speedtest
Under Qos setup in AP mode, when I try to test the speed, I get the error: The Speedtest failed to detect the bandwidth, please check your Internet connection or try again later. I get intern...
- Feb 29, 2020
Try setting the IP and DNS to Dymanic instead of Static...
Mar 01, 2020Guru - Experienced User
IT has been. You can wait for next FW update or ask for the beta.
Enjoy. :smileywink:
johnny5126
Mar 02, 2020Aspirant
I asked but never received a response.
- FURRYe38Mar 02, 2020Guru - Experienced User
Maybe today since the weekend is over. :smileywink:
If you don't get any responce, send me a PM.
- dglsmcd_USMCMar 02, 2020Luminary
I have the 852 in AP mode behind an ASUS router-when you go to the page in the RBR GUI which changes the RBR/RBS to AP mode it specifically says "Static" not recommended-I have used dynamic with the most recent firmware release and a couple betas without speedtest issues. FYI
IT has been. So you can use either Static or Dynamic. You can wait for next FW update or ask for the beta.
dglsmcd_USMC wrote:I have the 852 in AP mode behind an ASUS router-when you go to the page in the RBR GUI which changes the RBR/RBS to AP mode it specifically says "Static" not recommended-I have used dynamic with the most recent firmware release and a couple betas without speedtest issues. FYI
