JamesD7000
Apr 24, 2020Tutor
RBK852 compatibilty with RBS50Y
Hi, It does seem Netgear has not yet released an Orbi Outdoor Wifi 6 extender ... So, could the current Orbi RBS50Y be fully compatible with the RBK852 ? Thanks in advance for your comments
- Apr 28, 2020
For now, yes.
JamesD7000
Apr 28, 2020Tutor
Hi,
Thanks a lot for your insight.
Basically, if my understanding is correct ... should I desperately need to buy the RBS50Y Outside unit, as a consequence, it also means that I have to change my router and purchase the RBR50 ...
Thanks
Apr 28, 2020Guru - Experienced User
For now, yes.
- JamesD7000Apr 29, 2020Tutor
Hi,
Again ... Many Many Thanks for your precious advice ...!!!
- FURRYe38Apr 29, 2020Guru - Experienced User
Good Luck. :smileywink:
