Gilliland
Oct 07, 2020Aspirant
RBK852 connection issues with iphone 11 pro
I have a router and several satellites set up around my house, and have checked signal strength and latency throughout the house, and all seems fine. My iphone 11 pro, however, struggles to reconnec...
Mstrbig
Oct 07, 2020Master
Gilliland wrote:I have a router and several satellites set up around my house, and have checked signal strength and latency throughout the house, and all seems fine. My iphone 11 pro, however, struggles to reconnect to the network each time i reenter the network area. It first shows there is no internet connectivity as it is trying to connect, and sometimes connects after a few minutes, and other times i have to forget the network and reenter the password to get it to connect. Am using wpa2 security. my ipad does not have this problem. my iphone does not have this problem on any other wifi network.
Any thoughts how i fix this?
Seems to be an iPhone 11 Pro issues:
https://discussions.apple.com/thread/250659429
- GillilandOct 07, 2020Aspirant
Thanks for the response. What doesn't fit with it being just an iphone 11 issue is that my phone works fine with any other wifi system, just not with the RBK852 i have installed . . . I can't figure that part out.
