Gilliland
Oct 07, 2020Aspirant
RBK852 connection issues with iphone 11 pro
I have a router and several satellites set up around my house, and have checked signal strength and latency throughout the house, and all seems fine. My iphone 11 pro, however, struggles to reconnec...
Oct 07, 2020Guru - Experienced User
What version of iOS is on the phone?
Try forgetting the wifi profile on the phone then reconnect.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Armor, Circle, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Set CTS values to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
https://www.youtube.com/watch?v=unc36O66Ef0&feature=youtu.be&t=1062
Gilliland
firmware v3.2.16.6_1.4.4
ISP doesn't use a modem on site - it is direct over the air transmission to my property and then relayed over the air to a point close to the house, using a Ubiquiti system. That all was working fine with my phone prior to switching to the RBK852 system.
phone was running IOS 13, now running IOS14 beta. same problem with either IOS.
i have to forget the profile and reconnect each time to get a good connection after being away from the house.
large home - i have router and 3 satellites covering >5000 sf. not an issue for my ipad or other devices, just iphone 11 pro
routers are spread out, varying distances.
Using auto for channels. i can set manual channels but again this isn't an issue with other devices, so i question why that would matter.
no wifi signal from any other source anywhere nearby.
I don't know what the rest of your question means
- FURRYe38Oct 07, 2020Guru - Experienced User
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Set CTS values to 2347 under Advanced Tab/Advanced Settings/Wireless SettingsTry setting a IP address reservation for the phone ON the routers web page. Under Advanced/Setup/LAN setting.
I would make contact with Apple support on this as well. This seems to be a problem with your particular one phone device as your other devices are working with Orbi. I have seen other posts about users having problems with iphone 11 Pros before. I have a iphone 6sP was was on 13.6. Saw no issues with my Orbi AX sytem.
