DoctorA
Oct 26, 2019Luminary
RBK852 devices connected through ethernet ports are slow.
It is encouraging that some people are using this new system without any major bugs. Thank you FURRYe38 all other for your contribution. My laptop or desktop connected through ethernet ports of bo...
- Oct 31, 2019
Problem solved.
Connecting the ethernet wire from RBR 850 to RBS 850 must be the last step of the set up.
First I made sure the RBR setup is complet while RBS is not connected to the power. Connection speeds: Laptop wired: 950Mbps, I-phone XmaxS 650 Mbps in the same room.
Then I factory reseted the RBS and synced wirelessly with RBR 35 feet away.
After the Blue light on RBS is turned off and my I-phone Xs Max showed 400 Mbps, then I connected the in wall Cat 6 Ethernet wire from the cenral room where ONT, RGW and RBR 850 are. The wired backhaul method gave higher wifi speeds than the wireless backhaul. On I-phone Xs Max I got 600-650 Mbps. All the devices connected to the back of RBS are fine and my HTPC desktop 2 floors down gets 950-1000 Mbps.
My phone still gets 250 Mbps 2 floors away. Is this sattelite stronger than RBS50?
This 2 node system covers 5000sq f
schumaku
Oct 27, 2019Guru - Experienced User
DoctorA wrote:This, plus your suggestion to use this indeed "expensive'' system as only AP and your new information that the RBS50Y is only wireles made me to decide to get another system. I need a mesh system with 1 Router and 3 satellites in AP mode.
I'm convinced that the RBK852 system will grow up and the firmware will be enhanced over time.
DoctorA wrote:
I have 4 CAT6 jacks in my home. Perhaps AC3000 (RBK53) and one RBS 50. it will cost less with more coverage.
Are these CAT6 jacks all wired to direct the central room where the ATT RGW device is located? You might want to look into Netgear's Insight offerings for example, run some "core" switch there (PoE if some rooms require only a wireless AP), and a small Insight cloud manageable switch and an AP where you need both GbE ports and a WAC.
DoctorA
Oct 27, 2019Luminary
Thank you schumaku and others.
The "central" room is in the left corner of the 3rd floor. There are only 2 direct CAT6 wires there for the whole house.
One wire goes to the left of the 2nd floor where it connects to NETGEAR Unmanaged Switch (GS305) for my 5 AV equipments.
The second wire goes from the central room to Master bedroom where there is another NETGEAR Unmanaged Switch (GS105NA) where the RBS 850 is now. If RBS 850 was working properly I was hoping to get rid of the switch. From that switch there are wires in star formation to the 3rd floor balcony , 3rd floor computer room and then 1st floor theater room.
$700 satellite, wired can't function like a $30 dumb switch. Patiently waiting for the next firmware update because I like the 650 Mbs speed and coverage of this 2 nodes system. I don't have RBK 50 system to compair but the wireless signal is amazing. From 650 Mbps on the 3rd floor near RBR or RBS speed drops to 350- 400 Mbps second floor going trough tile floors and multiple walls. On the first floor 200 Mbps under 3rd floor satellite and dropping to 10 to 20s but no dead zone in the most difficult zones with concrete walls on 1 side. In the backyard there is no dead zones even at 100 feet away from the building and 150Mbps at 50 feet.
Can RBK 50 do this?
