ahswp
Jun 10, 2020Apprentice
Rbk852 dropping devices
I have an ORBI 852 using the latest firmware. I recently upgraded from the RBK50. Since upgrading 2 of my devices are not working properly - an OBI2162 wifi phone and my circle (version 1). The OBI...
Jun 10, 2020Guru - Experienced User
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Test the Orbi AX with AX mode disabled.
For any Circle related problems, please post in the Circle forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
There are known problems with Circle causing disconnects on Orbi AC systems and is advised not to use Circle until NG get that fixed.
