dmw_2's avatar
dmw_2
Guide
Nov 09, 2020
RBK852 firmware 3.2.16.6 question
I see that the release notes say this version now - Supports enabling or disabling the wireless 11AX mode on 2G or 5G separately - but I would appreciate some clarification.  Being unfamiliar with ex...
  • FURRYe38's avatar
    Nov 09, 2020
    Oribi WiFi 5 is AC mode supporting, this is just a wifi mode that supports higher speed than WiFi 4 or N mode. AX is wifi 6 thats just a mode that supports higher speeds than AC does. The support of disabling of AX mode is only disabling of the mode on either radio, not the radio themselves.
