dglsmcd_USMC
Apr 29, 2020Luminary
RBK852 Firmware Update V3.2.11.2_1.2.13
Not showing up on the NG server yet. Had to manually install-RBS850 FIRST-then RBR850 followed by a hard reset and fresh install-do not use previous config files. Here are the links: RBR850 htt...
Apr 29, 2020Guru - Experienced User
Wondering if this includes an AP mode fix...Hmm.
Thanks for posting.
Bug Fixes:
- Includes bug fixes for three Orbi Satellites that are connected to the Orbi network
https://kb.netgear.com/000061862/RBR850-RBS850-Firmware-Version-3-2-11-2
Off to testing we go. :smileywink:
- KMDonlonApr 29, 2020VirtuosoIs this beta or official firmware?
- FURRYe38Apr 29, 2020Guru - Experienced User
Anything posted on NGs support download site is not beta.
- DoctorAApr 29, 2020Luminary
What were the problems to begin with using 3 Orbi Satellites that are connected to the Orbi router?
I am successfully using 3 wired satellites for many months now, 1 RBS 850 and 2 RBS50.
Router is in Router mode.
