dglsmcd_USMC
Apr 29, 2020Luminary
RBK852 Firmware Update V3.2.11.2_1.2.13
Not showing up on the NG server yet. Had to manually install-RBS850 FIRST-then RBR850 followed by a hard reset and fresh install-do not use previous config files. Here are the links: RBR850 htt...
Apr 29, 2020Guru - Experienced User
Well sad to say that v11.2 doesn't fix RBS status in the RBRs UI when in AP Mode with a LAN switch in between the RBR and RBS. Still broke here. :smileysad: Take the LAN switch out and RBS status appears correctly in the RBRs web page and Orbi app with RBS directly connected ethernet to the back of the RBR. :smileywink:
Happy to report that in router mode on the RBR with a LAN switch in the middle and the RBS ethernet connected to the switch status reports correctly on the RBRs web page and in the Orbi app. :smileyhappy:
- FURRYe38Apr 29, 2020Guru - Experienced User
Also default values for CTS and RTS are at 64 in this version again. So for those of you seeing problems after you update, besure to set 2346 or 7.
- KMDonlonApr 29, 2020VirtuosoJust upgraded and my CTS/RTS values remained at 2347 as I previously had them set up. Weird yours changed back.
I should have mentioned that if you factory reset the values will be changed to 64. I factory reset my RBR. :smileywink:
