dglsmcd_USMC
Apr 29, 2020Luminary
RBK852 Firmware Update V3.2.11.2_1.2.13
Not showing up on the NG server yet. Had to manually install-RBS850 FIRST-then RBR850 followed by a hard reset and fresh install-do not use previous config files. Here are the links: RBR850 htt...
Apr 29, 2020Guru - Experienced User
Well sad to say that v11.2 doesn't fix RBS status in the RBRs UI when in AP Mode with a LAN switch in between the RBR and RBS. Still broke here. :smileysad: Take the LAN switch out and RBS status appears correctly in the RBRs web page and Orbi app with RBS directly connected ethernet to the back of the RBR. :smileywink:
Happy to report that in router mode on the RBR with a LAN switch in the middle and the RBS ethernet connected to the switch status reports correctly on the RBRs web page and in the Orbi app. :smileyhappy:
Also default values for CTS and RTS are at 64 in this version again. So for those of you seeing problems after you update, besure to set 2346 or 7.
