dglsmcd_USMC
Apr 29, 2020Luminary
RBK852 Firmware Update V3.2.11.2_1.2.13
Not showing up on the NG server yet. Had to manually install-RBS850 FIRST-then RBR850 followed by a hard reset and fresh install-do not use previous config files. Here are the links: RBR850 htt...
Apr 29, 2020Guru - Experienced User
Also default values for CTS and RTS are at 64 in this version again. So for those of you seeing problems after you update, besure to set 2346 or 7.
KMDonlon
Apr 29, 2020Virtuoso
Just upgraded and my CTS/RTS values remained at 2347 as I previously had them set up. Weird yours changed back.
- FURRYe38Apr 29, 2020Guru - Experienced User
I should have mentioned that if you factory reset the values will be changed to 64. I factory reset my RBR. :smileywink:
- McLongApr 29, 2020LuminaryNo new firmware found when checking within the App or web interface. Does anyone know why this update hasn't pushed OTA to the RBR852?
Current firmware: v3.2.10.11_1.2.12- FURRYe38Apr 30, 2020Guru - Experienced User
This seems to be a minor FW update vs Major. NG only seems to push major versions of FW so this version may not be pushed to the auto update servers. Which is ok. Manual updating works well.
- whoDeanApr 29, 2020Guide
I was able to manually update the router fine, but unable to update my two satellites. Prompts for the user name/password but will not accept the correct user/password combination from the router. Tried resetting both satellites and reconnecting to the router, no luck. So now I have mismatched firmware, with the router on the updated version and the satellites on the older version.
check that, it was some sort of stupid browser issue. Updating satellites now
