HiFiJP
Mar 28, 2020Tutor
RBK852 in AP with RBR50 Armor active
If I connect an RBK852 (in AP mode) to an RBR50 (with NETGEAR Armor and with WiFi radios off) does this in effect give the RBK852 NETGEAR Armor to devices connected to its WiFi 6?
- Mar 28, 2020Thank you, that’s great news. Sounds like a good work around until the RBK852 abilities are activated later this year.
Mar 28, 2020Guru - Experienced User
When in AP mode, the Orbi AX system is only working in pass thru mode so any connected devices with the Orbi AX system just gets the traffice passed thru to the RBR50 which will be handling and inspecting all traffic coming from the Orbi AX wifi system in AP mode. So in effect, yes. Armor processing is being handling at the RBR50, not any where on the RBR850 in AP mode.
HiFiJP
Mar 28, 2020Tutor
