AKLGUY
Feb 23, 2023Apprentice
RBK852 in Router Mode Internet Slows to 100MB up/down
Hi team I have had the 852 for a while now always had it behind another router and in AP mode but I wanted to use the VPN function of the Orbi. So I changed to the Orbi set it up in Router Mode. Got...
Feb 24, 2023Guru - Experienced User
Is this speed test with VPN active?
What do you see with VPN disabled?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
- AKLGUYFeb 24, 2023ApprenticeThe ONT is Chorus model 200
Pretty much the standard ONT in NZ
The providers router when in use is Vodafone Home hub.
Are you suggesting turn off the VPN see if the speed drops?
