leoport
Sep 28, 2022Aspirant
RBK852 is giving me high latency/delays during video conference (coming from Google Wi-Fi)
I recently switched to an RBK852 system from Google Wi-Fi because of various speed and coverage issues. The Orbi system blew my mind: 3x speed improvement, full coverage, fewer satellites. Everythin...
Sep 28, 2022Guru - Experienced User
I would try this to test. Change the SSID name or change the PW to something different so that it disconnects all wireless from the system. Turn OFF the RBS. With the one wireless PC check your app again.
For that size of home and distance, I would turn down the power transmit on the RBR from 100% to 50% as well. Under Advanced Tab/Advanced Settings/Wireless Settings
leoport
Funny, I was also thinking about trying the SSID name change (!). I'll be able to experiment later when I return home, but here is my list.
- Isolate the computer to a separate SSID with only the RBR powered on. Test.
- Turn down the power transmit of that RBR. Test.
- Analyze Wi-Fi channels for congestion (looks like inSSIDer has a Mac app in beta), try switching 2.4/5GHz to cleaner channels. Test.
Should I still do #3 and if so, if #1 and #2 don't show improvement, should I keep everything in the isolated environment (from #1)?
- FURRYe38Sep 28, 2022Guru - Experienced User
Yes try changing channels, try 1 and 40 first...
