Daveu
Jul 25, 2021Star
RBK852 keeps broadcasting default SSID
I've setup my new RBK852 with the RBS850 connected through the wifi backhaul. I've also got two RBS20s and one RBS50 connected by ethernet. I've set up my wifi and guest wifi with unique SSIDs. My ...
Daveu
Jul 25, 2021Star
It's coming from the RBR850 and RBS850.
Jul 25, 2021Guru - Experienced User
Try a factory reset on the RBR and RBS. After you reset the RBS, turn it OFF.
Setup the RBR from scratch and as you walk thru the setup wizard, be sure to input a custome SSID name that is different from the default one. Make it something fun. Can be anything. Once the RBR is setup, check on a device to see if the SSID is default or the new one...
