ahswp
May 28, 2020Apprentice
RBK852 keeps dropping 2.4GHz connections
My 852s keep dropping the 2.4 band. I have multiple devices that can only be used on a 2.4 band and these devices keep going offline. It seems that only my devices which connect on 5 band stay online...
May 28, 2020Guru - Experienced User
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
- ahswpMay 28, 2020Apprentice
I'm using the 852. I don't see many of those options in the settings. I have had previous netgear that did have many of those... but i don't see a way on the 852 to change fast roaming or 40 MHZ only. Also how do i change the preamble mode?
- FURRYe38May 28, 2020Guru - Experienced User
I forgot to take out "Armor, Circle, Daisy Chain, Fast Roaming" these won't be seen in the RBRs UI.
Others settings will be Under Advanced Tab/Advanced Settings/Wireless Settings.
Set preambe from Long to Short.
