prozone
Sep 07, 2023Follower
RBK852 maximum satellites
I am moving to a new apartment that is 3000 sqft in size but has very thick walls in between rooms. Am planning to have 6 satellites connected to the main router via backhaul. Is that possible? Any...
Sep 07, 2023Guru - Experienced User
I would be carefull having too many RBS in that size of home. Even with the building materials being a factor, you should look into may some Power Line adapters and connect two to maybe 3 RBS for ethernet backhaul instead of wireless and having too many RBS in that size of home. 6 would be too many. I'd try some PL adapters and try two RBS first.
Am planning to have 6 satellites connected to the main router via backhaul. Is that possible? Any one has any experience with that many satellites?
Thanks
