phusebox
Jun 30, 2020Guide
RBK852 Nat loopback bug on satellite
I have a domainname setup to access the NAS on my network. For example mydomain.com When I go to this domain on an external network, so out of home or on my phone provider, everything works fine. ...
Jun 30, 2020Guru - Experienced User
Something to contact NG support about and get additional help and information on.
phusebox
Jun 30, 2020Guide
Found out the issue only exists when the satellite is connected with a cable for backhaul . When it is connected wirelessly it works as expected.
Support won't do any good. I thought bugs were meant to be reported here?
- FURRYe38Jun 30, 2020Guru - Experienced User
No, contact and report the bug there with support.
When the RBS is wire connected, is it directly connected to the RBR or is there switch in between?
- phuseboxJun 30, 2020GuideA Netgear prosafe switch is between the RBR and the RBS.
What is the model# of the ethernet switch in the configuration?
To rule out the switch causing problems, directly connect the RBS the back of the RBR and test again with out the switch.
