phusebox
Jun 30, 2020Guide
RBK852 Nat loopback bug on satellite
I have a domainname setup to access the NAS on my network. For example mydomain.com When I go to this domain on an external network, so out of home or on my phone provider, everything works fine. ...
gb777
Jun 30, 2020Apprentice
Yep, it's a bug. Apparently, only select devices in Netgear's line up were chosen to receive standard functionality that meets RFCs.
Please ignore gb777 posts. They either don't know what they're talking about, or in the few cases where they do, choose to ignore it (the NAT loopback issue in particular was discussed here multiple times.)
phusebox
Jun 30, 2020Guide
An 800 Euro Mesh system that doesn't have the basic functionality of a 75 euro router... :(
If only that was the only shortcoming of this overpriced system.
- FURRYe38Jun 30, 2020Guru - Experienced User
Would be great to know if this happens with out the switch in line as well. Trying to gather some info.
What is the model# of the ethernet switch in the configuration?
If loopback is working with the RBR and not the RBS, lets try to figure out the RBS issue. Maybe if we can gather some info, we can work with NG on this. :smileywink:
Well if it's still a problem for you then ether contact NG support and let them know about it or return it and find something that works for you.
If only that was the only shortcoming of this overpriced system.- phuseboxJun 30, 2020GuideI will test it some more and come back on this. It might even be that the wifi part does support it and the Ethernet part doesn't. Will test that as well as without the switch. Replacing the switch for another one would be an easy and cheap solution.
Please post the model # of the switches you have. There are some odd issues with switches that can cause problems.
