phusebox
Jun 30, 2020Guide
RBK852 Nat loopback bug on satellite
I have a domainname setup to access the NAS on my network. For example mydomain.com When I go to this domain on an external network, so out of home or on my phone provider, everything works fine. ...
xtbe
Sep 25, 2020Guide
This sounds more or less to the issue I have.
I set up port forwarding to one of my pc's and set up DDNS. When I access from within the same network the DDNS address it works. However the RBK852 is to a GS116eV2. Every device that is connected to the GS116eV2 can't reach the DDNS address.
Additional info when I directly connect a GS105 switch and connect a pc to that one, then it works.
So it would look that there's something wrong or missing with the GS116eV2 but after reading this thread I'm not sure if the cause is the switch of the RBK852.
Thanks for any advice, hint, tip.
gb777
Sep 25, 2020Apprentice
Please try
echo 0 > /proc/sys/net/bridge/bridge-nf-call-iptables
