phusebox
Jun 30, 2020Guide
RBK852 Nat loopback bug on satellite
I have a domainname setup to access the NAS on my network. For example mydomain.com When I go to this domain on an external network, so out of home or on my phone provider, everything works fine. ...
phusebox
Sep 25, 2020Guide
I have given up. If I connect the satellite with a cable, I get this issue. With this issue the whole set is useless to me. Without the cable connection the mesh is mediocre at best.
Most overpriced useless router ever.
gb777
Sep 25, 2020Apprentice
What is "this issue?" Lack of NAT Loopback? Did you try the fix proposed and changed
bridge-nf-call-iptables
- phuseboxSep 25, 2020GuideI have no idea how to apply that and don't like messing about in things I have no knowledge of.
This NAT Loopback issue together with this set dropping all my Teams calls makes it completely useless... - gb777Sep 25, 2020Apprentice
NG actually sent me a test firmware that does nothing but change this flag. If you file a case with them, perhaps they send it to you, too.
- phuseboxSep 25, 2020GuideMaybe if they monitored their forum they would have noticed my bug report months ago.
I am done with this set. The mesh range is mediocre, the software is miles behind other brands and then there is these issues... - xtbeSep 25, 2020Guide
Hi,
Thanks for the help!
How do I get into the router, read that the telnet option is removed from the debug page. Should I use the script on Github that was mentioned in some other thread?
Thanks again.
/Tom
Folled the advice to execute
echo 0 > /proc/sys/net/bridge/bridge-nf-call-iptables
As soon as I did that the problem was solved. I can now connect to my DDNS address from my cabled connection
Thanks for the advice!
/Tom
